Bedlam
Apr 09, 2017Moderator
1. Your door latch needs to be adjusted
2. Your upper door frame needs to be slightly bent inwards
3. Your door seals need to be replaced or stuff nylon cord into them to increase material thickness
You get swirling wind due to the cab over. Any weakness in door sealing will be revealed with the camper loaded and traveling at higher speeds.
44,068 PostsLatest Activity: Jun 05, 2026
