Grit_dog
Apr 09, 2017Trailblazer
Bedlam wrote:
1. Your door latch needs to be adjusted
2. Your upper door frame needs to be slightly bent inwards
3. Your door seals need to be replaced or stuff nylon cord into them to increase material thickness
You get swirling wind due to the cab over. Any weakness in door sealing will be revealed with the camper loaded and traveling at higher speeds.
Not necessarily, and maybe it's only a dodge thing. You didn't get a lot of extra wind noise with your AF on your F250? Or new truck?
It's definitely the camper causing it. It makes such a vacuum that if I roll the windows down at 70mph or over, or if there's a head wind, it tries to suck the windows out of the frames! Have to slow down to get the windows back up.
I do have a low profile bug guard. Wonder if that contributes. Will take it off next time and see.
44,068 PostsLatest Activity: Jun 05, 2026
