falconman515
Mar 01, 2013Explorer
So from the looks of it I can remove these cross bars on the inside of the rock guard window, take out the rubber insert around the fiberglass and lip of frame holding it (uses same rubber tubing you would use on a screen door to hold in the screen) and the inside of the fiberglass rock guard is smooth and perfect!!!
I'm going to remove the fiberglass sheet, paint the current side white to cover the decals and what not and turn it around and throw a nice smooth layer of Fusion on the perfect back side of this and place the new decal on.
The back side has a nice smooth coating above the fiberglass ... and the front side is really sun beaten and you can feel the fiberglass with no type of coating anymore.
Once I flip this bad boy around place on the new decal and get some new rubber tubing to keep it secure and place the cross frames in again it will look great!
This should work good I hope ... here is a couple pics I took today.
