I had a clearance problem with the Wingman also
So I opted to put a Jack on
I then went with the
Rayzar as you can see it fits in the same space.
I opted not to put it on the supplied 13 In. arm. I kept one arm of the Winegard mast and mounted it that way,there are instructions in the kit,it is very easy to do. This way I had it in the same space and got the maximum height when deployed.
][IMG]http://i.imgur.com/TgLwTbbl.jpg" height=220>The Bi-Directional feature is great and easier to use than the Jack and I get a few more stations.
