rbadger28's avatar
rbadger28
Winter Camping Part time
Considering parking my travel trailer at rv park for duration of the winter but I will occupy only during the weekends. This wil allow me to travel to itthe location more freely as it is in high country and towing during snow storms is not an option.
Any tonight's / concerns on leaving my TT unattended for days or couple of weeks at a time during some cold snow storms? I am figuring whenever I leave it unattended I will pull the slide in and empty all tanks completely. I think roof can handle the weight of the snow.
Appreciate any experience in this. Thanks.
  • Why do I need to insulate the lines every time? If I bleed them of water each time isn't that fine?
  • Mine sits unattended for 4 months every winter just like many people in the north. Not a problem but in your case are you prepared to winterized the water lines every time you leave? Can you keep the water lines from freezing when you are using it? Can you reach the slide roof to shovel it off to retract it? Is the tt insulated enough and the furnace strong enough for the temps?
  • Be sure not to leave any food in it. You don't want a mouse invasion.
  • Well, there is snow and then there is ....snow. Around here, we get about 48" on average, a mix of wet snow at the beginning and end of seasons and mostly dry stuff between. There are also days of above freezing where melt occurs. If we get a lot of the wet stuff, I'll get on a ladder and pull off the wet stuff with a roof rake. I have the typical roof rake enabled with a pair of small wheels so the edge of the rake doesn't contact the roof surface.
    Beyond having a large amount of snow on the roof, there isn't anything wrong with your plan.
