1buda wrote:
Dumb question. We plan on camping on Thanksgiving weekend. What keeps the city water hose from freezing up at the camp site?
I'm in central Ohio right now, and just a heads up...it's cold.
I've got our hose wrapped in aluminum tape insulation, then have the heat tape (mentioned already on this tread) wrapped throughout the hose, taped every so often, then I have the hose wrapped in the foam pipe insulation, duct tape on the seams.
If you're only going to be a short while, I'd suggest just filling your tank and taking it easy on your water consumption. Otherwise, depending on where you are in Ohio, you might be able to get away with just spending $10 on foam pipe insulation at the hardware store and crossing your fingers.
Hope this helps!
