- HardscrabbleExplorer
specta wrote:
I am 110% pleased with these Michelin Agilis CrossClimate LT-metric tires.
They are three peak rated tires.
They are excellent tire with great reviews.
Just replaced my Goodyear Wranglers (had a hard 25k on them, TC onboard for about 17k, fine for non-winter driving but not my favorite tires) with these Michelin Agilis CrossClimate, E rated. In the North Country of NH, have driven in various winter conditions and find they are great. They are so much better than the OEM installed, they are quieter, great in the rain, are more surefooted. TireRack, got a great deal. - Bert_the_WelderExplorer III don't have a dually.....yet...... but I'm out in the sticks where we don't get plowed. Plus my driveway is steep and a 1/4 km long. I've gone up and down in a foot and a half of snow, unplowed. Both BFG KO 2's and Nitto Terra Grapplers did the trick quite well. The Nitto's are softer compound so wore faster (I keep the same tires 365/yr) and were a bit noisy on dry pavement. But the soft compound would a factor in being good in snow/wet.
Maybe a set that can be studded, if you're allowed? - Bert_the_WelderExplorer II
billtex wrote:
Subaru
Yep. That'll add a good bit of weight in the bed and if it's still running, you can just drive it on and off......;) - Grit_dogTrailblazer
redgart14 wrote:
I would recommend Cooper Discoverer. I bought a set of it from 4WheelOnline for winter last year and I'm satisfied with its traction and grip.
You realize there’s like a half dozen or more Discoverer models of tires.
From pavement pounders to mudders to snow tires. And everything in between. - silversandExplorer....from Quebec here. We've used BFG TA/Ko "three peaks" tires, and now Goodyear Duratrac (huge rubber blocks, very deep tread) "three peaks" snow rated.
....however, we very rarely ever actually drive in snow conditions, because camper is stored indoors 7 months a year. But that 7 months doesn't guarantee that we won't encounter snow storms in Quebec outside that 7 month winter period. I've had to drive in snow when camper was out of storage in Quebec maybe ~4 times. Glad I had the above winter-rated tires! Once, while heading across Wyoming on way to Salt Lake City on I-80, we hit a 300 mile, um, blizzard, with tractor-trailers and vehicles off the road along the entirety of this storm in June, glad we are always prepared with "three peaks". I've never worn down a three peaks tire on our truck camper rig before needing to change the tires due to "old age but with plenty of tread left" and/or sidewall cracking, with plenty of tread depth.
On edit: BFG TA/Ko and Duratrac aren't the only tires used in our region (Eastern Townships mountains region)...our tire place sells tons of Blizzak and Nokian three peaks winter-rated rubber..... - spectaExplorerThe three peak tires I have now are by for the best snow tire and all around tire that I've had on my truck.
I'm on my 6th set of tires, the five previous sets were AT tires and these out perform every one of them in the snow. MT tires would serve no purpose for me.
Winter tires are made of a softer rubber compound which generally wears quicker than all season tires.
Softer rubber compound means greater traction in just about every driving condition with the exception of extreme off-roading. - Beverley_KenExplorerAs Fisherman says, winter tires are mandatory, not just all season, or 3 season up here.
Quebec Winter Tires
Ken - redgart14ExplorerI would recommend Cooper Discoverer. I bought a set of it from 4WheelOnline for winter last year and I'm satisfied with its traction and grip.
- FishermanExplorer
jimh425 wrote:
It’s just a question of do you “really” want a true cold Winter tire or not. For sure, they are better in really cold temperatures, but they aren’t as good the rest of the time.
Otherwise, I think almost any M+S will be fine with a TC in the bed.
Some areas such as Quebec, you must have winter tires, it's the law. - BradymydogExplorer
TCjeff wrote:
Any recommendations for winter tires and wheels for our 2019 Ram 3500 dually? We live an hour north of Montréal Quebec. Winter can get nasty.
Previously, I spent quite some time working in Windsor,QUE. an hour east of Montreal. Also, Dryden, Ont 3 hrs north of Ifalls MN and Prince Albert, Sak. I suggest you contact a couple of local reputable tire dealers and ask for their recommendation. The road maintenance and weather up there is quite different than what I have experienced in the States. "Nasty", is putting it politely.
44,070 PostsLatest Activity: Sep 18, 2026
