I added some of the small 3-inch plastic VENTS (LOWES) on the inside walls of interconnecting cabinets inside the trailer. Just about all of my cabinets connect to each around the inside of my POPUP trailer.
On one end next to the POPUP trailer door I installed a 12VDC POSITIVE VENT AEXIAL FAN that is internal thermostat controlled that will pull positive air through all of my closed off cabinets. This pulls warm air from inside the trailer though-out the closed off cabinets...
I also have a couple of INVERTERs and my CONVERTER/CHARGER unit hat produces heat so this helps keep them cooler as well...
Seems to work for me keeping warmer air inside my closed off cabinets...
I got this idea from one of the guys on here that lives full time in his trailer.
Of course this doesnt address the underbelly tanks you need info on... Another guy on here uses HYDRONIC heat exchangers for his underbelly tanks. He uses hot water from his on board hot water tank and forces flow of hot water thru pipes around his underbelly tanks to keep them warm.
Roy Ken
