brholt
Dec 07, 2018Explorer II
bkenobi wrote:
NL said my furnace can't use the fan separate from the burner. In their opinion, I'd have to cut 2x 4" holes in the basement and install new fans.
That would work but not sure how to access the basement to do that. Wouldn't that require removing cabinets or cutting into the floor? That certainly doesn't sould like the cheap/quick solution I was hoping might be possible!
I don't know how NL builds their campers but if they heat the basement there pretty much has to be an inlet and an outlet. I get that the furnace can duct directly to the basement but I would think the air has to come out somewhere. That is where you could put a fan and have the air flow in the reverse direction.
