kohldad
Dec 07, 2018Explorer III
brholt has ssome good info. You could always add a small fan some place to move some are into the basement area.
I experience about the same temps here on the east coast and have never winterized my campers. My current non-basement TC sits in a storage yard so using electric heat isn't an option. All I do is go out when the temps will be below freezing, turn the furnace on lowest setting and let it burn the propane. Before I added a 100-watt solar panel, I would get about 3 days before I needed to pull the battery to recharge. For the few nights we see below 20*, I put it on the truck and bring it home so I have electric and the added insulation of the truck bed. Never had a problem with freezing lines. I can get about 40 nights of freezing temps before I even begin to worry about a tank of propane. That works out to less than 50 cents / night which is really nothing compared to the gas for a single weekend trip.
The black tank won't freeze down to about 10* because of the salts and contamenants. The gray tank will handle about the same temps before freezing. And even then, they only freeze to a brown slushy down to about 0*. So no real need to worry about them.
Fresh water tank takes a lot to freeze too. Just think of a bottle of water left in your vehicle. Just the bulk and being out of the wind and it takes a lot more than a single night into the upper 20s or lower before it freezes. Camping there is a case of water on my truck's back seat and usually a bottle or two in the doors. Even when I've woken up to temps in the teens, I've never seen ice in any of them.
