bkenobi
Dec 08, 2018Explorer
I got down and crawled around in the camper and found the return register under the stove. I pulled the vent off and then realized pulling the drawer accesses the same space. It looks like I could easily add a fan to the vent if I wanted.
After realizing how things were constructed, I removed some other drawers and found an extra spatula while inspecting the furnace lol... They installed an Atwood 7920-II furnace. That doesn't directly help, but it looks like everything is quick connect spades on the furnace. I should be able to find a manual/wiring diagram which would allow me to add a switch to turn the fan on independant to the burner. If I put the oil heater in front, it will circulate heat nicely I believe.
Unfortunately (or fortunately depending on the point of view), I found a water leak when looking inside the cabinets. Should be easy to fix (I hope). Appears to be either at the split line seam or the top of the propane box. I think resealing locally should fix it.
