jefe_4x4
Dec 10, 2018Explorer
Just a caution about blowing out the lines with compressed air. The one place that keeps water, almost no matter what you do is the bottom end of the water pump. I've been caught a time or two not getting all the fluid out and the pump went south as a result. In winter, without a basement or much insulation, plus our ancient Lance Camper, we run it dry for the 3 or 4 deep winter months using minus 50 RV antifreeze to flush the toilet and bottled water in burst proof jugs. This is the way when you have a long in the tooth Lance with a 2700 pound loaded weight. Probably less without the 18 gallons of fresh.
jefe
jefe
