bkenobi
Dec 05, 2018Explorer
Winter weather without winterizing?
I've had my 2007 NL 10'2"QRR for around 1.5 years. Last winter the camper was at the dealer for some work and all they had me do was drain the water and run air through the system. Neither I nor they put coolant in the lines. I don't want to winterize it now since I do plan on using it over the next couple months for a few weekends but the weather right now is down into the mid-20's with highs in the 40's. I have an oil heater in the camper and all the cabinets open, but that doesn't circulate any air through the basement where the fresh water tank is located. Is there any way to keep things from getting too cold without running the HVAC? I was thinking that all that's needed is a way to circulate the air so perhaps using some kind of an inline duct booster fan attached to and sealed over the furnace outlet? Or, run an inline booster fan with a hose running down under the sink?
Right now I simply turned on the light in the tank drain compartment which adds around 4W right under the black tank. I don't think this is a sufficient solution if it gets really cold, it's just all I have at the moment.
We only get temps in the 20's for a couple weeks in November or December and then again in February time frame. Outside of that, we only see mid to upper 30's as a low. I really don't want to run the HVAC since it burns a lot of propane and puts hours on the furnace for no real reason though it would keep things from freezing.
