bkenobi's avatar
bkenobi
Winter weather without winterizing?
I've had my 2007 NL 10'2"QRR for around 1.5 years. Last winter the camper was at the dealer for some work and all they had me do was drain the water and run air through the system. Neither I nor they put coolant in the lines. I don't want to winterize it now since I do plan on using it over the next couple months for a few weekends but the weather right now is down into the mid-20's with highs in the 40's. I have an oil heater in the camper and all the cabinets open, but that doesn't circulate any air through the basement where the fresh water tank is located. Is there any way to keep things from getting too cold without running the HVAC? I was thinking that all that's needed is a way to circulate the air so perhaps using some kind of an inline duct booster fan attached to and sealed over the furnace outlet? Or, run an inline booster fan with a hose running down under the sink?
Right now I simply turned on the light in the tank drain compartment which adds around 4W right under the black tank. I don't think this is a sufficient solution if it gets really cold, it's just all I have at the moment.
We only get temps in the 20's for a couple weeks in November or December and then again in February time frame. Outside of that, we only see mid to upper 30's as a low. I really don't want to run the HVAC since it burns a lot of propane and puts hours on the furnace for no real reason though it would keep things from freezing.
  • I never use the shower, but that's a good point. I should put some down the shower and bathroom drains just in case. The kitchen sink will be fine since cabinets are open, but bathroom isn't exposed either.
    I opened the drains last night. I decided 30ish gallons of water is cheaper and easier to replace than busted pipes. i'll blow them out today.
  • GordonThree wrote:
    What's the question?
    If you've blown out the lines, what's left to freeze?
    The drain traps... pour a little antifreeze down the sinks and the shower.
    Rob
  • In the time it's taken between your 2 posts in this thread, you could have winterized it....twice.
    Going to be low 20s here tonight and a few spots haven't lost frost in about 3 days.
    But if you've gambled and won, come tomorrow morning, then I guess you're fine.
  • If it makes you feel better winterize it.
  • Yeah, Seattle area here. I was told by people from east of the mountains that winterizing is critical but temps don't get as cold on the west side. I currently have water in the fresh water tank and the gray/black are empty. I could drain the fresh tank and blow it out, but since I want to use it in the near future seems like adding a little heat would be more than enough for our weather. But I'm new to TC's so I want to make sure I don't cause needless damage.
    Also, is there any concern that should be paid to outside shower head? I beleive I drained it last use but is that sufficient so long as we don't get a sustained freeze?
  • What's the question?
