joe_julie81ExplorerNov 20, 2020Winterization of hot water heater?After draining all the water from the tc,including removing the plug from the hot water heater, what else? The anode attached to the plug is half eroded away, I guess it should be replaced? Should ...Show More
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWinterizing tankless water heaterWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???
