Slymer
Nov 24, 2020Explorer
Don't do what I did,...twice.
If you have used your fresh water holding tank,....at all,.....be sure to drain it of course, but also, run the water pump, until dry. This gets the water out of the line between the fresh water tank and the water pump. Otherwise the one-way valve (usually plastic) will crack when frozen. That turns it into a leaky two way valve. Not good.
44,056 PostsLatest Activity: May 04, 2014
