valhalla360
Oct 25, 2018Navigator
Lemonhead78 wrote:
Can I turn my pump on and turn on the outdoor shower to check ? I wasn’t sure if doing this would be an issue. Thought I would lose some kind of pressure or something
Yeah, go out with the wife and have one watch at each outlet. Turn on the pump and open and close both hot and cold water. If all the faucets burble (might not be a hard flow) pink, they should be fine and since the pink stuff has displaced the water, no concern if there is a little air in the system.
I would also pick up another gallon of RV antifreeze and dump some down each of the drains (don't forget the shower) to be sure they did those (cheap insurance at $2-3/gal)
Did you fully empty your holding tanks and make sure there is ZERO water down at the valves? I'm betting they didn't. If you think you did, put a 5 gal bucket under and slowly open (ready to slam shut if needed) to get the last bit of water out.
Next time specify, they are to contact you before working on the RV.
