dodge_guy
Sep 22, 2015Explorer II
Do yourself a favor and drain the fresh water tank! If accessible remove the hose and put into a 5 gallon bucket filled with RV antifreeze. Then turn the pump on and push it through the system. Dump some down each trap too! There is too much of a risk of water collecting at a low point in one of the lines no matter how much you blow it out!
The little bit of water in the bottom of the tanks will not cause any damage.
