punomatic
Dec 20, 2016Explorer
burningman wrote:
I've been using the "EZ Bake Oven" method. I have a clamp-on utility lamp with a 100-watt bulb inside my camper, and it holds 40 degrees inside temp when it's low-20s outside.
It also keeps moisture down.
Used to do this with my boats. I had two clamp on fixtures and used heat lamp bulbs; opened cabinets and other closed spaces, like the bilge. Never had a freeze problem in twenty years of boating, even the time when the Columbia River froze hard enough for DW to walk all the way around the boat at the moorage! :E
