Jaxom
Dec 21, 2016Explorer
sonuvabug wrote:I don't actually "test". I assume...I know, I know...that the water pressure regulator won't allow excess pressure through the fitting. I simply screw into the city water inlet.Jaxom wrote:
To ensure that I don't over pressurize, I attach my water pressure regulator (the one I hook to city water at a campground) to my air line adapter. That should keep the pressure low enough to be safe.
Do you have to make some custom fittings to do this? and where do you pressure test ... I'm thinking the city water inlet?
The bottom item is merely an adapter to fit a different air line I sometimes use.
