DutchmenSport
Oct 11, 2013Explorer
I open the low points and let them drain, then put the caps back on, then I go ahead and "load" the pink stuff and do each faucet, hot and cold. While the pump still has pressure, and usually last, I crack the low point drains until they start leaking and spewing the pink stuff. If there is any water and usually there is very little water anyway, it will get spewed out. I then tighten the end caps and ... done!
44,066 PostsLatest Activity: Apr 16, 2026
