pasusan
Oct 11, 2013Explorer
I don't use antifreeze - just air. First I open the low point drains and the water heater drain (and the pressure relief valve) and open every faucet (including the toilet valve) and let everything drain. Then I turn on the water pump for a bit to empty it of water - leaving everything open. Then I shut everything off including the low point drains and blow the lines out with air opening one faucet/valve at a time starting with the furthest away and finally doing the low point drains one at a time.
Then I must not forget to take the gauge off the built in water regulator or it will not work next year and I'll have to get a new one.
Then I put the antifreeze in the drains and toilet.
Don't think I've forgotten anything. This has worked for me for many a year.
44,066 PostsLatest Activity: Apr 16, 2026
