WyoTraveler
Oct 11, 2013Explorer
If you are going to pump in the pink stuff you need to use water heater by pass valves. You don't want to get pink stuff in the water heater. If you are going to blow out lines withe air you don't have to be concerned with the by pass valve. I would decide which method you prefer to use and pose that question. I just blow my lines out with air. Still have to put antifreeze in traps, black tank to cover dump valves, in toilet to cover valve to keep it from drying out. If you decide to pump pink stuff through lines there should be a pick up hose for that near your pump or in your wet bay.
