cthompson
Oct 13, 2013Explorer
I have a Lacrosse. The water heater bypass is behind the panel as well as the water pump and RV antifreeze pumping line. I bypass water heater then put hose in gallon jug and start pumping untill pink stuff comes out off all faucets as well as low point drains. If you have a black tank clean out hook up do not forget to remove water from it. I forgot and the line froze and busted.
