BarneyS
Oct 18, 2014Nomad
If you have a black tank rinsing system installed, be sure to blow out the line where you connect the hose to. I failed to do that one year and burst a line someplace under my trailer. Have not been able to use the black tank rinsing system since. Need to get under there and take down the covering material to see what really happened.
Rob,
Those drain lines are most likely either the low point drains or fresh water tank drain. I have never seen a water heater drain other than the normal large plug on the outside of it. If you removed that plug and nothing came out then you are ok. No need to get every drop out.
Barney
Rob,
Barney
44,071 PostsLatest Activity: Aug 30, 2026
