hanks396
Sep 19, 2016Explorer
Winterizing question
I read all the directions on how to winterize my new TT, so I felt comfortable doing it myself. So I opened the drain valve on my fresh water tank to confirm that it was empty and only a small amount of water ran out (a cup or so). I closed the valve. So with that done, I went ahead and poured the red RV antifreeze into the fresh water tank. I opened the drain valve again to make sure that the drain line was filled with antifreeze, and it ran out crystal clear. I drained a couple gallons and it smelled like antifreeze, but it was totally clear. No pink whatsoever. I also put some into a container to see if it would look pink, and it was still crystal clear. I'm baffled. Any suggestion or explanations on why it is now clear instead of pink would be greatly appreciated!
