When winterizing, do you leave the pink stuff in the toilet bowl?? I've read the seals need to stay wet, but will the pink stuff damage them? Will it stayin the toilet bowl punk?
I keep it simple, bypass and drain water heater, open the low point plugs and faucets, drain or blow out the lines. Pump antifreeze out low point lines and cap them shut, pump antifreeze through all the faucets.
I dump antifreeze down the drains and in the stool. We usually do this while emptying out the food and bedding.
If it runs pink it is fine and I usually keep the faucets open.
