MitchF150
Oct 21, 2019Nomad
Are you just looking to drain it? If so, you can either pull the plug and let it drain, or open your low point drains and open the pressure relief valve and it'll drain from there.
If you are looking for by pass valves for RV AF, then that would be on the back side where the lines go in/out of the tank.
Good luck!
Mitch
Good luck!
Mitch
44,066 PostsLatest Activity: Jul 25, 2018
