KeithF40
Oct 22, 2019Explorer
Beverley&Ken wrote:
That white 'nut' is actually a nylon drain plug, use a 1" socket to remove, then open the pressure relief valve and it will drain the water heater. Important have city water disconnected/turned off and water pump turned off as well as turning off the heater controls, gas and electric (if equipped). Also water temp should be cool.
Bypassing the heater for winterization is done on the inside of the RV, behind the heater. One or three valve system.
Ken
If you don't relieve the pressure, before removing the plug, you will have an unexpected shower. plus the plug comes out much easier.
Is turning off the heater from the control switches (next to water pump) enough or do I have to turn off the breaker.
Also curious where in my picture is the pressure relief (I know some people said hot faucet is enough but curious).
