mike-s wrote:
Some states require breakaways, others don't. There's no federal (DOT) requirement, at least for non-commercial trailers.
OK..
Perhaps you care to point out the EXACT Federal regulation that says this?
Per
HEREIt states specifically that EVERY trailer that is REQUIRED TO BE EQUIPPED WITH BRAKES that a breakway system IS required. See text below and I will bold that part..
" § 393.43: Breakaway and emergency braking.
(a) Towing vehicle protection system. Every motor vehicle, if used to tow a trailer equipped with brakes, shall be equipped with a means for providing that in the case of a breakaway of the trailer, the service brakes on the towing vehicle will be capable of stopping the towing vehicle. For air braked towing units, the tractor protection valve or similar device shall operate automatically when the air pressure on the towing vehicle is between 138 kPa and 310 kPa (20 psi and 45 psi).
(b) Emergency brake requirements, air brakes . Every truck or truck tractor equipped with air brakes, when used for towing other vehicles equipped with air brakes, shall be equipped with two means of activating the emergency features of the trailer brakes. One of these means shall operate automatically in the event of reduction of the towing vehicle air supply to a fixed pressure which shall not be lower than 20 pounds per square inch nor higher than 45 pounds per square inch. The other means shall be a manually controlled device readily operable by a person seated in the driving seat. Its emergency position or method of operation shall be clearly indicated. In no instance may the manual means be so arranged as to permit its use to prevent operation of the automatic means. The automatic and manual means required by this section may be, but are not required to be, separate.
(c) Emergency brake requirements, vacuum brakes. Every truck tractor and truck when used for towing other vehicles equipped with vacuum brakes, shall have, in addition to the single control required by § 393.49 to operate all brakes of the combination, a second manual control device which can be used to operate the brakes on the towed vehicles in emergencies. Such second control shall be independent of brake air, hydraulic, and other pressure, and independent of other controls, unless the braking system be so arranged that failure of the pressure on which the second control depends will cause the towed vehicle brakes to be applied automatically. The second control is not required by this rule to provide modulated or graduated braking.
(d) Breakaway braking requirements for trailers. Every trailer required to be equipped with brakes shall have brakes which apply automatically and immediately upon breakaway from the towing vehicle. With the exception of trailers having three or more axles, all brakes with which the trailer is required to be equipped must be applied upon breakaway from the towing vehicle. The brakes must remain in the applied position for at least 15 minutes.
(e) Emergency valves. Air brake systems installed on towed vehicles shall be so designed, by the use of “no-bleed-back” relay emergency valves or equivalent devices, that the supply reservoir used to provide air for brakes shall be safeguarded against backflow of air to the towing vehicle upon reduction of the towing vehicle air pressure.
(f) Exception. The requirements of paragraphs (b), (c) and (d) of this section shall not be applicable to commercial motor vehicles being transported in driveaway-towaway operations.
Citation: 53 FR 49384, Dec. 7, 1988, as amended at 70 FR 48050, Aug. 15, 2005"Where that "law" varies is what trailers are "required" to have brakes.
Typically MOST states only require a trailer to be equipped with brakes IF it is 3,001 lbs OR MORE GVWR.. Please note, SOME states are more stringent and require brakes at 2,001 lbs GVWR AND HIGHER.
This DOES apply to not only "commercial" (AKA business) but NON COMMERCIAL trailers (AKA PERSONAL USE)..
I for one would not like to have someones 2K or even 10K trailer flying my way without a operating breakaway system.
