DWeikert
Dec 01, 2016Explorer II
One other advantage is it keeps the bags inflated to the minimum 5 lbs. Whether due to temperature, barometric pressure, or a slow leak, if you turn the key and the bags have less than 5 lbs, or whatever you have then programmed for, the compressor will bring the pressure up, or down if need be.
44,066 PostsLatest Activity: Mar 14, 2015
