Roman_Duck
Jun 03, 2014Explorer
Roman Duck wrote:
Go to home depot and get a Ryobi 18volt lithium battery impact driver for 99,00/
Use it all the time, We had a 30 class A that had no jacks, trying to keep the MH from rocking when walking was a real issue with the light sleepers inside. Bought the largest scissor jacks we could find and welded then onto the frame.
I would take the impact wrench (not a drill) and used the speed socket that I bought from CW to extend the jacks down to the point of lifting the wheel into the air, a lot easier than the hand crank
Copy this link and paste it into you address window
http://www.homedepot.com/p/Ryobi-18-Volt-One-Lithium-Ion-Drill-and-Impact-Driver-Combo-Kit-2-Tool-P882/203406854?N=5yc1vZc298
Get 2 for 99.00, I've used these tools in commercial construction for years, they have held up well.
Battery impacts turn at about 400 rpm max, which is slower than most drills of same voltage. not talking about the impact that is used on a wheel. drills work fine, but have a short battery life due to the torque required to set the jacks. Battery life will last 4 x as long in a battery impact driver, and really no nosier than a drill. The link above will let you do either.
