SoCal_traveler
Mar 23, 2013Explorer
Take out the guess work. Remove the battery, full charge it, let it sit for 24 hours under no use. Get a real hydrometer (not the one with the floating balls) and test each cell to see if you have short.
If just using the pump causes you to drain your battery, it sounds like a shorted cell.
Agreed with the info above, use new batteries not just one. The bad will leach off of the good.
Aloha ~ Todd
Aloha ~ Todd
