pianotuna
Sep 03, 2013Nomad III
Hi,
Use the size that is "one up" from the OEM wire to the RV. No one ever had too much voltage drop by using larger than needed wire.
You can order cables online or you can go to a local battery shop and have them made to order.
Be sure to use a waxy anti corrosion spray after the connections are made.
Heelshock wrote:
Wire question: What gauge wire to connect the 2 batteries together?
44,071 PostsLatest Activity: Aug 30, 2026
