Dragonfly's avatar
Dragonfly
WISDOM OF A HITCH EXTENSTION
We just finished our first trip in our 19 foot Airstream Flying Cloud. All went well except for one unanticipated issue. Having access to the truck bed for additional storage was important. But, the tailgate won't go down with the trailer attached. A short hitch extension I believe would solve the problem. I understand I will lose a little hitch capacity but I can tow over 7,000 lbs with my F150 with max load and towing packages and the trailer weighs 4500 plus contents. I was astounded how well the Airstream towed. I don't want to mess that up. I also hate to add about a foot of length since the rig fits EXACTLY in two parking spaces. But, it is rough climbing in and out of the truck cap window. Ford builds a TALL tailgate and these old bones are starting to age, hopefully gracefully. Any thoughts?
  • According to E-trailer, a hitch extension will reduce tongue weight capacity by half. At least as advised in this Q&A, a longer ballmount as advised above might be better, since no loss of TW capacity follows.
    Not sure how any of this will affect handling, though. Pic's sort of small so I can't really tell- it doesn't look like you're using W/D or sway control, both/either of which might help if handling problems arise.
  • A close up picture might help with suggestions.
    Some folks have been able to work around that problem by turning the tongue jack. Remove, turn it 90 degrees, and re-install.
    Some have swapped the jack for one with a smaller head.
    Some have moved the jack.
  • Which hitch are you using? If you are using an Equal-i-zer their standard shank is 12", but they offer an 18" shank which should minimally impact your towing/tongue capacity.
