- myredracerExplorer II
2012Coleman wrote:
Just getting back from a camping trip so haven't been around. The lance legs look very nice - where did you get them? There is about an 1.5 inch gap between the table and the wall so I will have to come up with a way to temporarily attach the table to the wall.
Our KZ dealer also sells Lance so they just ordered them in along with a shipment of Lance parts. I don't know if they're available from anyone other than a Lance dealer. I think they are around $100 for one leg and upper & lower flanges. - 2012ColemanExplorer II
myredracer wrote:
In a previous TT, I removed the standard wobbly legs and flanges. I attached the table to the outside wall with a detachable bracket and installed a single folding leg. The parts are readily available standard RV items. The problem going this route is that you will end up with holes in the flooring. Didn't matter to us though because we were installing laminate planks.
In our current TT, we installed Lance table legs and flanges. This is very stable, but attaching the table to the exterior wall is even stronger (providing the exterior wall doesn't flex). We went with the Lance legs because we would have had exposed screw holes from the old flanges.
Just getting back from a camping trip so haven't been around. The lance legs look very nice - where did you get them? There is about an 1.5 inch gap between the table and the wall so I will have to come up with a way to temporarily attach the table to the wall. - AJRExplorerOn a previous camper I used a nicely painted 2x4 with Velcro on the wide surface that held it to the wall. Velcro on its narrow surface held the end of the table. The inner post was removed. Worked very well.
- Opie431ExplorerOurs has never wobbled due to a wall support but talked to a man who stopped over at a campground who put a piece of wood 1x3 against the wall from the floor up for the table top to rest on. I did not ask how he had attacted the strip of wood to the wall.
- seaeagle2ExplorerOur dinette has a single post and a strip of wood on the wall, I got some Velcro tape and applied it to the wood strip and the bottom of the table. It's working so far.
- martiprExplorerI replaced the legs with these:
http://www.factoryrvsurplus.com/products.php?product_id=1965
and we love it. The table is very steady, can be moved about, even taken outside if you want. For travel just fold the legs and place the table as like to make a bed. The picture shows cream color but they are actually black. - myredracerExplorer IIIn a previous TT, I removed the standard wobbly legs and flanges. I attached the table to the outside wall with a detachable bracket and installed a single folding leg. The parts are readily available standard RV items. The problem going this route is that you will end up with holes in the flooring. Didn't matter to us though because we were installing laminate planks.
- WayneAt63044Explorer III just slam the Trailer Life directory on the table above the 2 posts to tighten it. Only need to do it a couple times a year.
- 2012ColemanExplorer IILooks good SoundGuy. We don't use the table as a bed, but it may be in the future when my son gets old enough to bring a friend. I'll look into your solution as well but maybe try to find some kind of latch to replace the L brackets in the second picture.
- SoundGuyExplorer
2012Coleman wrote:
What have you done to stabilize a wobbly dinette table?SoundGuy wrote:
Depends. If the table is located alongside a wall then it's an easy fix, one I did myself in our previous KZ Spree, but if it's a table that's part of a U shaped dinette with no wall next to it then that would require an entirely different approach. Whatchagot? :@2012Coleman wrote:
Table is located alongside a wall - not U-shaped.
That's easy then ... pics of my solution are here and here. I wouldn't waste the effort fooling with those pedestals, trying to make them tighter, as they'll just loosen up again. Secure the table edge to the wall and it'll be dead solid ... only downside is if you want to use the table as a bed - with a triple bunk bed camper we didn't so it was a perfect solution for us.
44,070 PostsLatest Activity: Sep 18, 2026
