myredracer wrote:
sherrycalh wrote:
myredracer wrote:
The typical RV pedestal legs do wobble quite a bit regardless. There are some ways to replace the legs with something better which is what we did.
YES, that is what our flange looks like. Only one is loose on the floor. What did you use that was better?
We have aluminum table legs that Lance uses as in this photo. The flanges are much wider. VERY solid and almost no wobble at all. They look nice too. They are made by Tacomarine.com. They don't sell to the public but you can get them from a marine store or a Lance dealer.
On a previous TT I took the standard pedestal legs out like you have and mounted a bracket at end of the table to the wall and a folding leg. Both are standard RV accessory items. Only thing with this is you're left with holes in the floor from the flange. Not a problem in our case because I also installed new plank flooring. If not fussy, you could always use a little dab of vinyl flooring seam sealer in the holes.
That set up from Tacomarine is really great. I was able to remove two of the crummy chrome steel posts and replace it with one of those. So, so, so much better. I ordered them through a marine supply online that I can't seem to recall the name of!
