There's only so much prep work and research one can do before actually taking the plunge. I knew we needed some things, mandatory safety items before we should try to make a trial run, but at some point the fun takes over and you just want to be sitting in your own digs, checking out the scene!
I had found the following at wally world: RV water hose, water pressure regulator, jack pads, cleanout adapter for the waste hose, and a few other minor things. I hooked up the power cord -- VERY glad that Northwood gives you a decent electrical cord with plenty of length. We had a devil of a time figuring out the hot water (or lack of) until we finally found the hot water tank bypass valve was set wrong. Thank goodness the tank already had water in it.
The Fox Landing is a thing of beauty. We probably would not have gotten it but it came on this one anyway so we lucked into it I guess. Love it! It is perfect for lots of different reasons and is fodder for its own thread.
One more pic before I begin to be more critical and start running numbers and stuff.
