austingta
Feb 27, 2018Explorer
brianosaur wrote:BlindGuynAR wrote:
I think that truck has a factory installed brake controller. The pic of the AC controls shows -+ controls on the bottom left. That's a brake controller. I'd run with it, but the P2 is a fine unit.
Apparently, you are correct!
Honestly, I knew a bit more about the truck then the salesman did, just by reading up on most of the specs before I went there.
I specifically asked about the brake controller on the dash. He said he *believes* the controller in the truck is for the adjustment of the 'trucks' abs while towing and not for the trailer.
However, I just looked in the manual and it says it has and Integrated BC.
2016 F250 Owners Manual - PAGE #200
Quick Ref Guide - Dash #9
Wow. Anything else he told you is suspect now too.
