Trackrig wrote:
If you get a slow roof leak and the water runs slowing down the insides of the wall or stays up in the ceiling causing the wood framing to rot out. With aluminum framing you'll still have repairs to make, but you'll know the framing is still solid and it's worth repairing. The aluminum framing also probably makes the trailer lighter if everything else was exactly the same.
Bill
Sounds good in theory, but once you get water in the walls you have delamination and it probably wont be worth the expense to fix it anyway.
