JIMNLIN
Sep 27, 2019Explorer III
LuckeyUs wrote:
Is the wood or the Aluminum frame sturdier? Thanks!
More fodder.....
This from NUWA about aluminum vs wood construction;....which was posted a letter form on NUWA website for years.
Why doesn't NuWa use an all aluminum structure like popular Indiana manufacturers?
NuWa made the decision to begin the use of aluminum structure based on marketing and the fact that many people were concluding that an "aluminum caged" product was superior in construction technology, weight and strength. Our 40+ years of experience as a leader in 5th wheel design suggests that may be "flawed" information. We have proven that wood construction need be no heavier or less strong than aluminum construction, that is built properly. We now build both materials, and are comfortable doing either, however our opinion is still that wood construction provides a superior product, and today we use both in the construction of our trailers. The strength of the NuWa trailer is actually created by the superior and light weight Blue Dow foam lamination concept.
NuWa uses an aluminum substructure in the sidewalls and ends of the coach only. No aluminum in the floors or attics, where metal promotes conduction of cold and moisture resulting in condensation.
90% of the walls are Blue Dow Structural Foam, rather than wood or aluminum. This creates a superior insulation and the only product with a guaranteed sidewall R Factor. (Water absorption in standard white foam reduces R Factor over time, and the use of Blue Dow Structural Foam eliminates this problem.)
NuWa's aluminum substructure sidewall is actually a "hybrid" wall, as we core fill the aluminum with wood in those areas where additional strength is required, because aluminum will not hold a screw. Not so with the lower priced brands. With NuWa's combined use of wood and aluminum substructure, you get a superior product because of NuWa's unique Blue Dow foam vacu-bond process, which makes the sidewalls virtually resistant to water penetration.
44,072 PostsLatest Activity: Aug 23, 2026
