LAdams
Nov 13, 2012Explorer
Excellent job!!! Better than new... Nice to see a true craftsman at work :W :B
BTW, I looked at your first post and your using the wrong syntax from Photobucket for posting your pictures... Use the last choice in the list under your pictures that says "IMG code"... Just click on that in photobucket and you will see the word "copied" when you do that... Then just paste that syntax into your post here on RV.net... Below is an example from one of pictures on photobucket...
Note the text that says "width=640"... If you type that into your copied IMG syntax from Photobucket after pasting it into your post here, that will automatically resize your photo to the correct maximum size for RV.Net and it will hold the correct constraints for width/height ratio as well...
![](http://i19.photobucket.com/albums/b191/nomad27/resizingimagecode-1.jpg)
Les
Les
44,025 PostsLatest Activity: Feb 06, 2025
