CavemanCharlie
Mar 01, 2019Explorer III
spoon059 wrote:
Rubber pads won't stop the trailer from leaving indentations, it will just be that much more noticeable. If you are only there for a couple days a year, why not just get a couple of 2x10 boards and put them under the tires? That would spread out your weight over a larger footprint.
t.
Ya, spread the weight out over a larger area.
Or, could you add a small cement pad where the wheels go ? Leave it below the level of the grass and mow right over it whenever your TT is not setting there.
Or, could you dig the dirt up where the wheels go and use packed gravel ? Packed gravel would not sink (as much anyway). Keep the gravel below the level of the grass and mow right over it.
