SilverEscape's avatar
SilverEscape
Would you tow this trailer home?
We're looking to buy a 2015 Jayco X213 and would be picking it up 6 hours away. To get it home, we'd need to use our MDX. There will be a more capable tow vehicle added to the family, but it's not available at this time so will either use the MDX or not buy the trailer.
Trailer stats:
  • Brochure dry weight: 4005 pounds
  • Brochure tongue weight: 390 pounds
  • Yellow sticker weight: 4300 pounds
  • Trailer won't be loaded with any cargo other than a few accessories that are bought like levelling blocks and a few other gadgets. Will need to consider that for tongue weight...maybe carrying water would be enough to make tongue heavy enough? or is tongue already going to be too heavy with trailer weight 4300# in real life?
Vehicle stats:
  • Towing capacity: 5000 pounds (includes two 150 lb passengers and 15 lbs cargo each and we weigh less than that)
  • Max tongue weight: 500 pounds
  • Class III receiver
  • GVCWR: 10,053 pounds
  • Weight distribution hitch not recommended
  • Manual recommends tongue weight of 8-15% for non boat trailers (I know 10 should be minimum, just wanted to point out what the manual says)
  • Sway control will be there (have to research what to get yet)
  • Has Trailer Stability Assist feature which uses the VSA feature to determine if a trailer is causing vehicle instability (during sway or oscillation) and then "The control unit sends signals to selectively apply the brakes and regulate the engine output."
  • Has a Prodigy brake controller
Very flat roads, almost nothing for curves either. Will be content with reducing speed to 90 km/hr or lower if need be.
Opinions? And if you think it's doable, any advice or recommendations would be awesome. Thanks!
