Lantley wrote:
Larry JT Strong Arms are available for TT's as well.
JT's for TT's
I do have JT's on the front and rear of my fiver.
Jt's provide a real stability solution.
Thanks and I knew JTs can also be used on TTs and I'm not and haven't said they won't help, it's just IMO the are still what I call a bandaid and a major argument against what I'm advocating and those with the scissor jacks is the hassle of having to get down and put the screw jack stands under the trailer, but to fix the poor stab jack design one has to get down even further under the trailer TWICE with Stab bar supports to tighten either one or two of the screws that hold the arms in their extended position and again to loosen the screw to retract the jacks. Thus the argument about having to knee down and even crawl up under the trailer is more of an issue if one has the scissor type stab jacks and have installed the additional stabilizer bars.
Larry
