gregrc75 wrote:
Larry-
I usually use x-chocks, stabilizers, and a pair of jack stands in the middle of my travel trailer when set up. I still experience a decent amount of movement with these in place. I have been reading this thread since it started a few days ago. So, curiosity got to me this afternoon. Since the snow had melted and it was a warm 40 degrees, I pulled out my jack stands and tried the method you described. I have to say, just with those 4 jack stands in place, it is way more solid than any other time I have set it up. I See what you are saying that a rear living room floor plan may have a bit more wiggle so I am thinking of using that Valterra stabilizer across the back bumper to help eliminate the back end bounce/wobble. Using that, and installing my x chocks, I think I will be very pleased. Thanks for you suggestion.
You are very welcome and glad to help and again I doubt anything except the "mobile home cinder block system" is going to be 100% effective, 100% of the time. However, having used this portable screw jack stand system for over 20 years and been completely happy I was appalled at what was included on our current 2007 Trailer and fortunately I had kept the old stands from 1981 which I'm still using to this day. It's being able to help folks like you that are adventurous to step out of the box that makes me endure some of the skepticism sometimes when I suggest these NON STANDARD things. I can't comment on all these wheel chock devices since I'm a plastic ramp sort of person and just like to keep it as simple as possible for the most part. I completely removed all my OEM stab jacks (BTW I then shaved over 50lbs from my TT weight in the process) so I don't even have one at the very end of the trailer, but that works for us and as I said being able to do w/o that set at the very end is going I think be very dependent on the exact TT, floorplan and how you use it. A lot of TT's have a bunkhouse back there and if you have little ones I can see where you're going to need that extra support.
One other suggestion is you might need some experimenting in finding the best placement and especially using that set of jacks at the end and how you tension them using the tongue jack. IMO you're never going to get enough support with these screw type scissors jacks by just using the screw part, but to be honest I haven't needed to experiment much with that issue. A real bonus is that I found the front jack stand placement just happened to be close to the door so the movement from going in and out was virtually eliminated when I put my jackstand in that general area around the door opening.
Again it is ABSOLUTELY CRITICAL that you get sufficient weight transferred to those jackstands and the only way I know is to use the tongue jack with the tongue up tongue down routine ... trying it with just the screw isn't going to cut it.
I'm a die hard believer in trying to keep things simple under the trailer from a maintenance point since I had our last trailer for over 20 years and know what time and long term exposure to that harsh environment will do to things. I try my best to make sure anything under the trailer if possible uses things like SS, aluminum, brass, rubber, nylon bolts/nuts, etc. so things like rust and corrosion is minimized. One of the first things I did was to replace all the sheet metal screws that held up my coroplast underbelly to the frame rails with nylon bolts and washers so I had a hope of removing them at sometime in the future if that was every necessary.
Larry
