Just recently purchased a X213 which we dearly love. However there is one problem with it. Once you bring the bumper slide into the camper one of the cushions for the table is wet. Somehow moisture is...
thanks for the advice. I checked and what is happening the bumper slide bed is not centered on the opening. therefore on one side the rubber strip that should be touching the bumper to wipe off moisture coming in is not effective. can you adjust the entire slide out to center it back in the opening? thanks for your reply
