HMS_Beagle
Apr 07, 2022Explorer II
It looks pretty good, I do have to raise the camper another couple of inches higher to put it on or the valence will scrape the roof.
Now does it work? I just drove 900 miles from Napa to Anacortes, Wa. All the way up the Sacramento Valley on I5, about 25 knots of north (head) wind. Calmer weather in Oregon and Washington. The wind noise seems to be reduced, in that I can hear the tire noise and engine noise more distinctly. It isn't silent still, but improved. I've made this same trip several times recently, and the fuel mileage was about the same, at least within the range of variation. I've gotten as much as 14.5 for this round trip and as little as 12, this time one way 12.6 which combined with the headwind for the first 200 miles probably about the same.
The aerodynamics are certainly different, opening the window produces a slight breeze from the rear, opening the back window produces almost no wind, just lets in more road noise. If I stick my hand out there is accelerated air coming around the edge of the dam, and very little wind on top of the cab. It produces a faint wind whistle between about 35 and 45 mph, but goes away above that speed.
Now the problems. When I stopped for fuel in Oregon (it isn't any cheaper in Oregon right now than California - what's up with that!!??), I noticed that the slight distortion had become a large cave in. It hadn't hit anything but air and the occasional bug. With the middle caved in, there was a bug spatter pattern emanating in a V from there across the cab roof going aft. I still have a bug pattern underneath the overhang about matching the one I'd marked out prior to the dam, though fewer of them I think. I also had bugs across the camper bulkhead near the top, again like before the dam but not as many. How much of that is due to the failure of the valence to hold it's shape is a good question.
* Adjusted image size using width=640
44,071 PostsLatest Activity: Aug 30, 2026
