- dodge_guyExplorer IIAnd thankfully it blew up out of the chassis, saving a perfectly good Dodge/Ram from damage!
- JarlaxleExplorer II
Chuck_thehammer wrote:
my Guess... something went WRONG with there Math...
140 pounds of boost....
and what 12 to one.. 15 to One compression ratio. my guess.
Crankshaft Main Cap Failure... ??????
Probably not...I expect it was a competition pulling engine. - Bird_FreakExplorer IIIs this The little Engine that Couldn't?:B
- dodge_guyExplorer IISee how powerful the Cummins is? Even after the block is gone the crank is still spinning!
- HannibalExplorerAll four of my Cummins Rams blew up, caught fire and burned down my 5th wheel! Pretty cool it was still running after it blew.
- Wild_CardExplorer
17:1 compression ratio - Chuck_thehammerExplorer
Um, optimum compression ratio for diesels is 16.5 to 1, so I doubt it would be as low as 15 to 1.
YOU ARE CORRECT... for normal boost...
must lower compression as boost levels go about 40 psi... - danrclemExplorer
gbopp wrote:
We've finally found something that can't be fixed with Duct Tape. :)
You have obviously never heard of a man named Red Green. :B - naturistNomad II
Um, optimum compression ratio for diesels is 16.5 to 1, so I doubt it would be as low as 15 to 1. - spoon059Explorer III
mich800 wrote:
Yea, but the great thing about this is no cost cab removal... Won't get that with a Ford!
Dodge guys brag about no cab off repairs. But I am guessing this would make a cab off experience whether they wanted it or not. :B
44,066 PostsLatest Activity: Apr 15, 2026
