APT wrote:
The dry TW exceeds your receiver limit and will likely increase from there. I recommend an upgraded truck, 3/4+ ton.
That right there is enough to void the whole thing, so worrying about payload and tires is moot... ;) Your receiver is rated at #1150 TW using a WD hitch setup, so if the dry TW is already #1180, you are pretty much done right there..
I guess you could load #2000 of toys in the back of the TH, but then that would likely make the tongue too lite and it won't tow very well..
Good luck!
Mitch
